The trunk was the only bad part but I got it pretty much fixedLooks good bro! Sounds like you deadend the car very well, no rattles outside.....me likes //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Well I hope they do what I want which is to be louder if not I will have to look at the 15"alpines I'm very happy with them I have them in 1.8 cu ft each and it seems to slam pretty good also I'm running a soundstream TRA 1400.2 bridged @ 4ohmsFrom what I have experienced, the P3 are not comparable to Type R's. I have never heard them in decent enclosures though, only shitty ones that my friend built.
there are more brands than Rockford and Alpine //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gifWell I hope they do what I want which is to be louder if not I will have to look at the 15"alpines I'm very happy with them I have them in 1.8 cu ft each and it seems to slam pretty good also I'm running a soundstream TRA 1400.2 bridged @ 4ohms
Yes I know I should have also stated that I did not want to spend a bunch and my car has a pretty small trunk so I'm kinda limited if I want to run a ported box. If I could have what I want I would get some MMATS juggernautsthere are more brands than Rockford and Alpine //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
FTWYes I know I should have also stated that I did not want to spend a bunch and my car has a pretty small trunk so I'm kinda limited if I want to run a ported box. If I could have what I want I would get some MMATS juggernauts//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
will do thanks for your opinionHide some wires on the next insteak ok? so much cleaner and takes like zero time.
I wouldnt expect a big increase in output going to the p3's they dont get very loud, the type r's in a slightly bigger box with a better amp would be MUCH better. check out some of the R setups on here, they can slam pretty good
