xtremekustomz
Anyone use a variovent (aperiodic vent) for their midbass? If so does it work well?
Usually completely sealing kickpanels worsens the midbass....unless you have absolutely huge kickpanels.I think all sealed up tight keeps the midbass strong.
Never done a true AP enclosure myself. And frankly, they have kind of gone by the wayside these days.Anyone use a variovent (aperiodic vent) for their midbass? If so does it work well?
AP enclosures are used to flatten the impedance curve of the speaker, giving a relatively flat and relatively predictable frequency response (before vehicle acoustics are taken into account) while being very small in physical dimensions.all it would do is show the speaker a slightly larger enclosure.
you may be able to hold a flat response into lower frequencies than you would without it, but you wont gain any output.
Two main drawbacks for AP (in general) is decreased low frequency output and decreased efficiency.i don't know enough about flow resistors to know whether or not there's any drawbacks, so i can't really recommend it.
I guess the OP needs to clarify if lowend response/output is his main problem...because I guess that's not what I interpretted his posts to mean.Most people use polyfill to increase lowend response, rather than a resistor
Then moving them to the kick and going AP very well could work out for you.My problem is with imaging from the doors with the frequencies going as high as they do. Some things tend to pull down towards the doors. Low end response and output is definately not a problem.
I've done a few things with the phase but it only gave me more depth on most things. Most of everyone I have talked to told me to put the midbass in the kick since the frequency went up so high.Most stage height issues can be addressed with tuning, depends though. I'm assuming you've played with your x-over points, as well as phasing.
No. 8" midbass in door running from 63-900 hz, 3" dome midrange running 900-4500 hz and 1.1" tweeter running from 4500hz and up. The midbass is in the door, the midrange and tweet are in the kick panel.I'm assuming this is a 2 way setup, mids in doors tweets in A-pillars? That's just what I'm guessing though. If so then a AP setup might be a good idea.
