SOLD us amps chrome 2000x
sancho20
ImageShack Album - 3 images
Im selling this for a friend thats getting out of car audio.He wants $500 for it and i dont know how flexible he is on the price.you all know what these amps can do and how hard they are to find.I know you can find them cheaper sometimes but i looked on ebay to see if there were any on there and there was a black one for $799 .I know he wont get that but im sure he will get $500..
It was sold eh? So these sell well... //content.invisioncic.com/y282845/emoticons/up2something.gif.dd110ecf3ae4b76050d87598f2f8de7c.gif
These sell to mainly one person //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Just to let you guys know. This amp will pretty much blow any class d 3k amp out of the water.
A local friend and competitor used to run 4 of these.
They are rated 2000w@4ohms mono. they were clamped at 3010.
US AMPS USA2000X
The USA2000X by US Amps is the odd-amp-out in a couple of respects. First off, this was the only one in the test to use class A/B topology. Under normal conditions when an amplifier is not being pushed to extremes, class A/B amps are not nearly efficient as class D or T. However, SPL competitions present a different situation. As these monsters are often played into a serious clip, the efficiency of a class A/B amplifier can measure closer to that of a class D or T.
The USA2000X also is the only 4-ohm stable amplifier of the group. However, this did nothing to deter the beast from producing impressive numbers. Our in-lab results showed it to be quite powerful, making 1685 watts with 12.5 volts, and a more impressive 2100 watts with the juice increased to 14.4. This placed it third in both categories. But placing the USA2000X on a reactive load drastically changed things. Here it took top honors with a very impressive 3010 watts. This is largely due to the 4-ohm impedance design (as opposed to the 2-ohms in the other amplifiers in this test). Therefore, the USA2000X should make more power at the test frequency of 50Hz where the impedance of the speaker rose to 5.3 ohms. In many ways it is fair to say that US Amps had an unfair advantage in our test since the output would likely be higher at this impedance.
The ones my guy had produced 3082w@4ohms mono clamped at 14.2v. At the most pressed load it drew about 350a of current. When overdriven to moderate to heavy clip it produced about 3200w.
And this is all at 4ohms!!!
474
587
Hello all. Used to come on these forum quite a bit. I used to compete in IASCA MECA etc. and placed 1st 2x with this setup. Anyway this is my baby...
You don't need two amps. The speakers come with crossovers to help protect the tweeters.
14
Perhaps you changed something without mentioning it here? Maybe a loose turn on line? I dunno man...but we'll take it. Hopefully it keeps working. 👍
16
sancho20
sancho20
tampa bay ,florida
resko1
