Sold US Acoustics USB4085 & USB2150
for those that want pics here they are
Mustang COBRA pictures by gentlejax - Photobucket
USB4085:
RMS Power Output (Watts x Channels) 85 x 4
Peak Power Output (Watts x Channels) N/A
Power at 2 Ohms (Watts x Channels) 120 x 4
Bridged Power (Watts x Channels) 240 x 2
Minimum Impedance Bridged 4
Minimum Impedance Unbridged 2
Frequency Response at Rated RMS Power N/A
THD at Rated RMS Power 0.01%
Signal to Noise Ratio 101 dB
Input Voltage 12.9v
Amplifier Class AB
Low-Pass crossover Frequency 40-200Hz
Low-Pass Slope (dB/octave) 24dB
High-Pass Crossover Frequency 12-200Hz
High-Pass Slope (dB/octave) 12dB
Preamp Outputs 1 pair
LED Power Indicator Yes
Width (inches) 16-7/8
Height (inches) 2-5/8
Depth (inches) 9-5/8
USB 2150 is similar
2 x 150 @ 4ohm 12.9 volts
2 x 225 @ 2ohms
1 x 450 @ 4ohm
last chance
specs for the 2150
2 x 150 @ 4ohms at 12.9 volts
2 x 225 @ 2ohms at 12.9 volts
1 x 450 @ 4ohms bridged at 12.9 volts
THD less than 0.01%
Frequency Response: 10Hz-30kHZ, -0.5 dB
Input Sensitivity: 100 mV - 8.0 Volt
Crossover range
Low Pass: 40 - 460 Hz
High Pass: 65 - 4.5 KHz
S/N Ratio: 103 dB
Channel Separation: 90 dB
Damping Factor at 20 Hz: 95
Reverse Polarity, Thermal, Short Circuit, and DC protection.
Fuse Rating: 20A x 2
Size: 14.6 x 9.6 x 2.5
gentlejax
gentlejax
Bossier City, La.
gentlejax
