skeptikal
Premium Member
Hold the wheel and drive
Ok I am just trying to clear a few things up before I actually do this just to make sure I will do it right.
So I run another ground wire from where my amp is already grounded back up to the negative battery terminal right? Since my amp kit is already a 4ga i should be ok running and 4ga back up there if that is what im supposed to do?So, from your battery, you have the power wire going to the power terminal on your amplifier and then your amplifier is grounded to the chassis of the vehicle. From here the current needs a way to get back to the negative battery terminal, and that way is through the first of the "Big 3," the battery negative to chassis wire. Upgrading this wire will "upgrade" the circuit between your battery and your amp by giving the current a larger path to flow through to get back to the battery.
