Upgrading amps, suggestions?
capil
Buying new amps:
Need a 4 channel and a mono block.
4 channel for the front stage/ Or could be a 2 channel. Need 150 to 170 watts rms at 4 ohm. Must be class AB
And the mono must be 500 to 700 watts rms max. At 2 ohms and must be class d
For the front stage I have DD 2 way components. 125 watts rms per side (ran passive)
For the sub I have a jbl p1224 (400watts) And also have a idq 12 (750 watts rms)
Wanting Matching amps of good quality and wanting to use the mono amp for both subs ( as I have the jbl in a ported single box) and the idq in a sealed box. And will swap the subs over every now and then. So want the mono amp has to be compatible for both subs.
Any suggestions.? Can't find any matching amps to suit yet. Like Rockford fosgate and alpine but not sure.
Cheers
capil
capil
new Zealand
capil
