Upgradeing
subzero
I dont think my t5-12's are loud enough anymore.
The box I am using is 3.5 cubes tuned to 32hz.
They are getting 1000rms-2000rms @ 2ohms from strapped amps.
This set up did 144.2 in Nov.
I want to get different subs. the box has to be the same size or is wont fit in the car.
My budget would be $600.
I am open for sugesstions.
I listen to everything, Rap, Rock, Hiphop, Jazz, Techno bass, Classical. and I like it loud continuously.
The speakers I use are listted in my sig. They produce decent midbass.
I will get more speakers and midbass if needed to match whatever subs I get. So, any sugesstions. The following subs have been mentioned to me:
MTX9500series T9512-04 (x2)... probly wont be able to fit 2 in the trunk. so it might get 1 T9512-44.
Soundstream SPLX 12's
Any other sugestions.
putting a 15 in there might be a challenge. I think I only have 16 1/2 height space but the real problem is putting the box in the car
Build the box in car? That an option? And the 1-2k range of power...is that power per sub or total?
If you're looking for louder, it might not hurt to try a 15. As much power as you have thrown to a power hungry sub might get you the results your looking for. I've seen pretty impressive scores on here from 1 15.
Well, I guess you guys are suggesting that "one" 15 is going to be louder than two 12's... ? I guess I will have to figure out if I have the room for a 15. It was a pain in the *** putting these 12's in there.
So, If I put a 15 in there which one should it be?
I been looking at the MTX 9500 series. What is your take on the MTX's
I could do two 12's, But the displacment might be way too much. So I would end up having to just do one.
In that case I might as well settles for the 15, easier to work with since these subs have deep mounting dept and a greater displacment that my current subs.
T9515-04
Any other recomendations. perhaps the XXX 15 soundstream? Show me a good deal on those...
subzero
subzero
Chandler, AZ
subzero
