I have some pretty bad alternator whine and some thumps (when turning car on and headlights on) but the thumps aren't too bad.
Here is some common answers to questions you guys would probably ask.
- The power wire is ran along driver side of car, remote middle of car, and signals on passenger side.
- Sub amp is a Fosgate T1001bd, speaker amp is JL HD 600/4, and deck is a Pioneer deh-p980bt
- Amplifier ground is to a well grounded (verified with ohmmeter) spot in the trunk. Both amps go to a dist block first then to the ground bolt in the trunk.
- Head unit ground goes out to engine bay where battery grounds to chassis.
- All noises go away when RCAs are unplugged which I assume means the head unit is the culprit.
- Running a wire from the ground to the RCA shield doesn't change anything.
- I havent yet ran a dedicated power and ground from deck straight to the battery (next on my list) but does it even matter?
- The 3 RCAs (front, rear, sub) are new and pretty solid. American International (a division of BML Industries, Camarillo, CA) Part# HPC-20 CL
So any ideas or any other questions for me? I'm thinking about taking apart the deck as I heard there is an internal 'fuse' (essentially a thin piece of wire which burns up) that when blown it can cause issues like this. Is this true about the internal fuse?
