Sold Underrated reliable korean power anyone???
infamous_e46
hArRy_DaNgLeRs
most recent pix i took for a possible trade with ttimhouse74
Power Output
RMS @ 4 Ohm: 700W x 1 Ch.
RMS @ 2 Ohm: 1300W x 1 Ch.
RMS @ 1 Ohm: 2500W x 1 Ch.
RMS @ 1 Ohm: 4000W x 1 Ch @18v
Signal to Noise Ratio: >100dB
THD (IHF-A): 0.2%
Input Sensitivity: 0.15V – 5V
Input Impedance: 47KOhm
Slew Rate: 10V/USec
Damping Factor: 300 @ 4 Ohm
Fuse Rating: EXTERNAL 200A Fuse
Dimensions (in mm):
Width: 240mm
Height: 61mm
Length: 570mm Features
MOSFET Power Supply Amplifier.
Double Sided Through Hole Epoxy PCB.
Gold-plated Brass Set Screw Terminals.
24dB/Oct. Crossover - Variable Low Pass Crossover (40Hz ~ 200Hz)
Variable 24dB/Oct. Subsonic Filter 10Hz ~ 70Hz
Variable Phase Shift
5 Way Protections
Daisy Chain Through Output RCA
Bass Remote Control
Power/Protection LED
1 Ohm Stable Circuits
Soft Start/Output Relay
18V Operation
Parallel Operation
405 shipped conus including all fees o.b.o
ah same board as the vfl 150.1 thats why it reminded me of a hifonics board. bx2200d iirc
that amp should make some good power then.
cant believe at the price it hasnt sold...
too many nutthuggers lolz
free bump
TTMFT !!!!!!
and ill do it every 30 minutes if ya want just to piss off cj lolz
infamous_e46
hArRy_DaNgLeRs
infamous_e46
California
Jaredturp
