underbody Neons...off roader ?
i think ur ****ed with the idea of neons - unless you have them mounted with plugs 4 the power and you make them easily removable for off roading - that would be about the only way i see it happening
underbodies on a wrangler??!?!?! //content.invisioncic.com/y282845/emoticons/nono.gif.eca61d170185779e0921b0faa9704973.gif//content.invisioncic.com/y282845/emoticons/banghead.gif.8606515f668c74f6de0281deb475b6fd.gif i wont even address the issue of if you could do it, because you SHOULDN'T.
I think easily removable ones like crankupdabass mentioned. you could run a small strip of velcro the length of the tube and another strip on the frame and just have it attached that way. Im not too sure how well that would hold though.
Originally posted by ridered36 I think easily removable ones like crankupdabass mentioned. you could run a small strip of velcro the length of the tube and another strip on the frame and just have it attached that way. Im not too sure how well that would hold though.
w/ some heavy duty velcro it would work
Well, the tubes are made from Lexan...which will withstand most flying rocks and such. . . but if you hit it with a boulder it would crack no questions asked.
I would need pictures of your underbody to show you where some possible installation spots would be. Other than that, you could just go removable style...
- Steve
lephatrabbit454
lephatrabbit454
ny
ss3079
