ummm
bass_mekanik
i got 0.5 2 go til 145dbs
do you guys reckon this amp sounds nice i am thinking of getting 1 to power a pair of type S 10's and possibly getting another 1 if i like them so then i have 1 runing each sub price is $335 dollars australian each they come well reckomended from a friend but i would like to get more opinions
Quoted direct from Jaycars website
2 X 150WRMS Mosfet Car Amplifier
This power amplifier is designed for high performance car-audio installations and is rated at a huge 150W RMS per channel into 4 ohms. Power dissipation into 2 ohms is an impressive 230 watts RMS per channel. The amplifier can also be wired in a bridged configuration to deliver 450 watts RMS into 4 ohms. Fitted with gold plated RCA input connectors, the amplifier features variable input sensitivity from 200mV to 3.5V, Hi/Low filter switch, variable crossover frequency from 30Hz to 130Hz,
adjustable bass boost from 0 to 12db plus overload & short circuit protection. Speaker and power connection is via gold plated terminal blocks.
Specifications-
Power/channel @ 4 ohm: 150 W RMS x 2 -
Power/channel @ 2 ohm: 230 W RMS x 2-
Power output (Bridged 4ohm): 450 W RMS x 1 -
Frequency Response: 20-30Khz ± 1db-
Total harmonic distortion: Less than 0.08% @ 1kHz -
Input sensitivity: 200mV to 3.5V-
S/N ratio: Better than 80db @ 1kHz -
Maximum current: 56A.
not to sound like a dick but some peps don't liek can't afford or can't get JBL amps in my case jbl amps aren't accessable at a far price and that amp has been said to be reliable so what do you guys think
bass_mekanik
bass_mekanik
Launceston Tasmania
bass_mekanik
