Ultra Subs SS-6 Componets
mr Tibbs
Well, this is going to be my on going thread for my Ultra Subs SS-6 comps review. These are the comps that I won in the vendor give away. The Ultra website for these comps can be found here. My thanks goes out to IamMurph and all of those at Ultra as well as Ant for the Second Skin trunk pack. I will use the deadning in the FJ install. I say on going because these will be in two different vehicles and used in two different ways. I'll be updating the thread as I get the comps installed into the second vehicle and be giving my on going opinion as well.
The first vehicle that these will be going is in my car, a 2002Saturn SC2. I know, laugh it up, but it cost me $6000 and it gets 36 mpg. Done laughing, good, now on with the review. Currently (well up until today) installed I have the Seas 18RNX mids with the LPG tweets running active using my Pioneer 860mp as the x-over. The amp I am using is a Phoenix Gold Xenon 100.4, 4 channels at 100+ watts a channel. Traditionally I have been very pleased with this set up, but it seems I am always playing with the settings. It seems I just can't get it just right. To start off the Ultra comps will be a direct drop in replacement for the Seas and LPG's. They will also be run active.
Anywho, let's start off with some pictures. Here are the Ultra mids, they seem pretty beefy. Not too much to look at, but I kinda like that. I like when a company puts the money into the sound of the speakers, and not the cosmetics.
Take a look at the rim of the speaker. The top layer is a plastic guard piece I am guessing. The second layer is the basket itself, and the third (bottom) layer is my favorite. It's a foam gasket of sorts. I found this to be very cool! I don't think I have ever tested a speaker with a foam gasket on the mounting side before!
Here is the back side of the speaker. Nothing too fancy, but you can see the foam gasket a little better.
Here is the mid mounting system. Pretty standard from what I have seen in the past. Simple yet effective.
Here is a pic of the tweet in it's mounting cup.
Backside
Here is the tweet mounting system. I always worry about this when I buy comps because I never really know what to expect. No two companies seem to do this the same way and don't really elaborate on how they do it. After playing around with these I like the mounting options. I will most definitely try to flush mount these in the FJ. They do rotate around in the mounting cups a little so aiming them is pretty easy.
So, that's it for the initial pics. Next post is the install pics.
After taking the initial pics I dug in and tore apart my doors to do the install. Here are a few comparison pics and the install pics.
Ultra on the left, Seas on the right. Notice the difference in size. The Ultra is a 6.5" and the Seas is a 7".
The backside comparison. Notice the difference in motor size and the vent hole. I'm not sure what that has to do with anything, but there is a difference.
And a side comparison shot.
Here are the tweets. LPG on the left and Ultra on the right. After playing with both of them I actually like the Ultra mounting options a lot better. They are much easier to aim.
And here are the install pics. Here are the mids installed on the spacer that I made to compensate for the depth of the Seas mids. I probably could have removed them, but I didn't want to rip up the ensolite. After installing the mids I made sure that there was still a good seal all the way around the speaker and the spacer. All is good.
Here is a shot of the door without the door panel. All of the holes are for mounting of the door panel. Notice the ensolite that is falling off. I resprayed that so hopefully it won't come off again.
And here is the finished install. Notice the tweet in the sail panel. It's not flush mounted, but it is solid and will do for now. I used the mounting system for the Ultra and I was able to aim these.
That's about it for the pics. I'll start another post with my initial thoughts and keep going from there.//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Now on to the initial thoughts of the sound these make. That is what we are after right?//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif I'll start off with the technical stuff. Here is how I set the x-over points initially:
Sub (LPF) 63hz with a 24db slope and reverse phase
Mids (bandpassed) HPF 63hz with a 18db slope
LPF 2.5khz with a 12db slope
Highs (HPF) 2.5khz with a 24db slope
After a little tweaking here is where I ended up leaving them:
Mids (bandpassed) HPF 80hz with a 18db slope
LPF 3.15khz with a 12db slope
Highs (HPF) 3.15khz with a 24 slope
I may play around with them a little more but I think I'm close.//content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
So, how do they sound?? Well, initial thoughts are they are **** nice!! Right up there on par with the best stuff I have ran. First CD in was Alice In Chains - Unplugged. I was doing a lot of tweaking with this so I really didn't give it a fair shake but it sounded really good. The plucks of the guitar strings were present with authority, but not overpowering. Layne's voice shined as always, and overall the CD sounded good.
Next I threw in the DIYMA SQ CD as I call it. First song I played was Dire Straights - Money for Nothing. HOLY S#*@!!! The drums were right in front of me, with authority! The voices were at eye level in front of me, ****!! This was what I was hoping for. Loud, and clear with authority. Just sonic bliss. I played this song about 4 times through before I made myself try something else.
After that I listened to Fleetwood Mac, Clapton, The Eagles, and that one some about Keith Don't Go or something like that all with similar results. Even the Dr. Dre track sounded really good, but made me realize something. I had to turn my sub down. For some reason it was getting overpowering. After a few little tweaks it just seemed to blend right in. So, I had to go back to Dire Straights to see if it effected that bliss. Nope, The authority of the drums seemed to shift from behind me a little bit to in front or slightly to the side. I actually like this a lot better.
Next I threw in some Days of the New. This is my safe CD. I have listened to this sooooo much that I seem to know every note by heart. I started off with Provider, and as always it sounded great. This song starts off slow with a single guitar then kicks into gear with Travis Meeks vocals. The guitar sounds soo **** good with this set. It seems to shine even more with the Ultra's than with the Seas for some reason.
After that I tried many of my favorite songs and found myself just listening to the music. Somewhere in there I stopped trying to pick apart the speakers and just enjoyed the music. This IMO is one of the highest compliments I can give these. Seriously, this is why I have dumped all of this money into a sound system is to just enjoy the music I love. I'm very pleased with this set so far.
A few notes before I end the initial review. At first I thought the tweets were less harsh that the LPG's but after listening to them I thing they are a little brighter. Maybe it's the different x-over settings, maybe not but I think I'm going to have to EQ these down a little bit. And speaking of EQ'ing, after tweaking here and there it looks like I am a lot close to having a flat EQ than I had before. I'm a hell of a lot closer to dead center than I was with the Seas and LPG's. I'm not sure what that means, but I thought it was worth mentioning.
So, there is the initial review. I'll update this in a week or so with my findings, then in two weeks or so I'll transfer them to the FJ and use the passives. I'm looking forward to the next few weeks, so far these are everything I have hoped for!!
Just a quick update guys. I ran into a little snag with the FJ so I still have these in the car, and I'm still loving them. I have a dash kit and a wiring harness for the FJ on the way and it should be here on Tuesday. I'm installing a Kenwood XXV-01D in the FJ and finally ditching the stock deck. So hopefully by the end of the week I should have these installed into the FJ and have some initial thought for you guys. Thanks for being patient with me guys and sorry to the guys at Ultra for taking sooo long. I am enjoying them in the car though!!
mr Tibbs
mr Tibbs
Utah
mr Tibbs
