Ultra Rare Subwoofer - I need some help finding some specs. Someone please help!
1000 would probably be safe and make it move a good bit in 4.5 cubes. Just from the looks of it, and something about how old it looks makes me feel this way, I would think the Fs on it is pretty low. Just looks like the cone would flop like a flacid dick so you could get away with tuning around 32 easily to have something that could play a tad bit lower if you're into the lower bass.
So how would you recomend the port?
---------- Post added at 08:45 PM ---------- Previous post was at 08:45 PM ----------
Like i said its going to be in the trunk of a 2012 civic coupe
Im not looking for somthing perfect i was just looking for 34hz around 1000ws concerning trunk space is not that limited but is limited to the access so 4.5 cubes is pretty easly optainable.
---------- Post added at 08:48 PM ---------- Previous post was at 08:48 PM ----------
Im sure its built by atomic its similar too a atomic beast
attachment.php
????? What?
---------- Post added at 10:06 PM ---------- Previous post was at 10:06 PM ----------
Depends, I would stick with no more then 1500rms daily.
For enclosure I would suggest around 4-4.5ft net with generous port area.
Thanks for the help!!! Very thankful
I found this information about the sub after alot of searching
Revc 8oms
Fo 39hz
Sd 0.089 sqM
Bl 38.73 TM
SPLo 91.81 db
Xmax 18.75 mm
Dvc 75 mm
Oms 9.97 m.q.
Qes 0.0337 e.q.
Qts 0.0326 totQ
Vas 82.88 liters
Cms 73.68 uM-N
Mms 268 grams
ChronicSPL
ChronicSPL
Boston Area, MA
ChronicSPL
