Two simple Q's
GreenBook
Is it bad to have too deep of a box? I'm considering having another go at it & try to build something bigger. I have plenty of trunk depth from seat to trunk latch but not nearly as much between the wheel wells. In order to get a decent sized box it'd have to be pretty rectangular.
Also, as a general rule of thumb; when you guys post box spec's on here are you guys talking before or after sub displacement?
To question one:
Not particularly bad. But, if it's too big, the weight of the top could kind of sag down. So you might want to think of bracing it a bit. A simple dowel in the center should suffice.
As for question two:
Most of the time, it's net (After port / sub displacement.)
To question one:Not particularly bad. But, if it's too big, the weight of the top could kind of sag down. So you might want to think of bracing it a bit. A simple dowel in the center should suffice.
truth
Thanks for the really fast response. What if the box was built so the subs had individual chambers? I guess it really doesn't matter, but i'd just prefer to have them seperated.
GreenBook
GreenBook
Michigan
GreenBook
BP1Fanatic
BP1Fanatic
