Sold Two Image Dynamics 10" IDV.3 Subs FOR SALE
Troydb
I am selling these two subs because I am going to a single sub setup. I bought these brand new and have only been running them the last few weeks. They are DUAL 4 OHM subs and are in excellent nearly new condition!!
Subs come with the original boxes.
Here's a couple of pictures:
$85 for each sub or $165 for both of them.
Here's the specs from ID:
Nominal Impedance (IMP) 2/8 ohms
DC Resistance (Re) 1.8/7.2 ohm
Resonant Frequency (Fs) 23.2 Hz
Electrical "Q" (Qes) .387
Mechanical "Q" (Qms) 3.714
Total "Q" (Qts) .350
Equivalent Volume (Vas) 2.43 ft3
One Way Linear (Xmax) 17.0 mm
Cone Area (Sd) 350 cm2
Sensitivity (Spl) 86.5db
RMS Power Handling (Pwr) 50 to 400
Speaker Displacement .05 ft3
Recommended sealed box: .40-.80 cubic feet
Recommended ported box: 1.37 cubic feet @ 30Htz
I had them on 200W RMS each and they sounded great. I would describe them as a good SQL sub. They have a very accurate sound to them but the 17mm Xmax gets them pretty loud too. I guess that sums up all the ID subs.. just a good mix of SQ with SPL.
You think they will handle 1000watts? lol
Is your amp 1000x1? If so they would be seeing 500 each which is probably ok as long as your gains are kept down. They are rated at 400W RMS, so it's your call.. you can always try it and see //content.invisioncic.com/y282845/emoticons/veryhappy.gif.fec4fed33b4a1279cf10bdd45a039dae.gif
Troydb
Troydb
Down South
SPY
