Two Atomic AT-3000.1
sojiaraggs9000
I've got 2 Atomic AT-3000.1D amps. Both have plexibacks. These use the same boards asthe Saz3000, DC PAI 3000.1 and the RD3250.
If you have a DC PAI 3000.1 id trade you one amp straight up for it.
Specs:
* Digital mono block amplifier
* Dual MOS-FET power supplies
* Efficiency over 86%
* RMS power handling---1000w @ 4 ohms @14.4V
* RMS power handling---2000w @ 2 ohms @14.4V
* RMS power handling---3200w @ 1 ohms @14.4V
* Signal-to-noise ratio 85dB
* Phase shift 0-180 degree
* subsonic filter: 10-60Hz
* lowpass filter: 35-300Hz
* Input sensitivity: 200mV -6V
* 3 way protection: over voltage, speaker short & thermal overload
* Total harmonic distortion:
* Continuously variable 0 – 18dB Bass Boost
* Built - in variable 0 – 18dB per octave x’over
* Power Consumption
* Size: 23.25” x 10” x 2.20”
$500 per amp plus shipping. $800 plus shipping if you buy both amps.
See above.
"I've got 2 Atomic AT-3000.1D amps. Both have plexibacks. These use the same boards asthe Saz3000, DC PAI 3000.1 and the RD3250."
Great amps, only thing, you shouldn't compare Atomic's product to any other companies product as if Atomic's inferior to them, because if it weren't for atomic those type of companies wouldn't even exist. Atomic has had their designs either bought or copied time and time again. They are the originators of high powered Subwoofers, and even though they're more geared towards woofers, companies like those you mentioned and many others wouldn't exist if it weren't for atomic. Being more of a woofer company, Atomic did use to share boards. But no matter what, you gotta put atomic at the top, because they are the ones who's been taking Car Audio above and beyond since 1946. Their product is amazing, GLWS
HAHA thanks for the info. But I in no way ment that these amps where inferior to any of the amps I listed. I just mentioned that they all use the came zenon boards. Ofcousre componets will vary but as you said these amp are VERY much high end quality amps.
sojiaraggs9000
sojiaraggs9000
West Tx
sojiaraggs9000
