Two 10" audiobahn immortal
On each sub it has four different terminals of positive and negative. I guess for each voice coil I need to know how to wire those properly because a buddy of mine undid all the wires on the sub itself.
You could wire each sub to .5 ohm, 2 ohm, or 8 ohm
I would wire both to 2 ohm and then wire them together for a 1 ohm load.....
And I would get them in a smallish ported box
3-3.5 cubes at 34hz....
Just get about 1500rms for the pair.....
An Audiopipe 1500d would work good.....
That wouldn't work for him, He has 2 quad 2 ohm subs.....That site only shows how to wire single and dual....
to be honest that did slip my mind but he could just select 4 speakers, dual 2 ohm coils. hes wiring 8 voicecoils together right? im assuming it would work out the same.
You sir are correct!
Mrpolo, Use the link above, Wire each sub as 2 dual 2 ohm subs to a 2 ohm final load....Then just wire the 2 subs together and it will be a 1 ohm final load which is what most monoblock amps put out their most power at...
mrpolo
mrpolo
Alabama
mrpolo
