tweeters making a odd sound
king ranch
Banned
i have a set of polk momo hooked up to a zx850.4 and giving each side 135rms and just noticed it when i have the truck key turned over but not cranked the tweets make a slight tssssss sound almost like a static sound and then when i crank my truck its even worse and thats with the HU off
when i turn the Hu on its still there and once i turn the volume up it seems gone but i cant tell since music is playing as well
i have my rca's and power wire on the same side and i am using cheap rca's walmart series so that might be the problem but wouldnt my subs and mids be making the same sound bc they arent
any idea's
thanks
if its happening with the HU off then your tweeter wires must be touching metal/grounding out. check the wire for cuts or pinches.
if your HU is off then the amp is off. that means your amp is not giving the tweeters any power. so something elce is, or elce they wouldnt be making any noise rite?
i have gains set with dmm on a 1khz test tone and no my amps are hooked up in my fuse box on a spot that has power only when key turned on so when i turn my hu my amps stay on
but foreals change ur rcas to the other side and get some quality ones if that doesnt fix it check your wiring and mess with ur tunning while you hear it to make it go away or not
king ranch
Banned
king ranch
fl
king ranch
