Tsunami 1800
BumpinDoug
15A's B!TCH
Just got my new Tsunami DB1800 Class T amp.....oh man this thing is sweet. Shipped in three days, cant wait to hook it up. Anyway, im hookin it up to two 15A's, Both dual 2 ohm voice coil. Box tuned to 30 HZ. Apline 9815 HU with 4 V preout. 12V battery and 14.4 when alt. is on. Im basically amp illiterate....kind of. Well i thought I knew what I was doin but i guess i dont. Anyway, I need to know how to set the follwing...
-Variable Input Sensitivity 250mV to 6V
-Variable Low Pass Filter 50-250 Hz
-Variable Sub-Sonic Filter 15-50 Hz
-Variable Phase Control 0-180 Deg
-also, the manual had something very confusing written in it. Like theres 2 ports to connect your subs, each with a + and a -. Now i was planning on jsut wiring everything to 2 ohm and plugging it in as a mono setup all into the one port...but it said if you plug it in to one port not to go any lower than 4 ohm? Then it showed a diagram where two subs were plugged into both ports and it said it could go down to 2 ohms this way. That confused the hell out of me. So I have to hook up each sub and plug each one in at 4 ohms? Wont that only get 900 watts out of the amp or will it give out 900 each??? Im real confused, please help, i know a lotta you got this amp and know how to do thsi shit so help me out!
BumpinDoug
15A's B!TCH
BumpinDoug
Atlanta
BumpinDoug
