Treo 10" ssi Help
skeleto
I want to build a ported box for this sub. the manual specs say it should be 1.25cuft tuned at 27Hz. I came across the moes designs boxes, there is one for 1.25cuft tuned at 32hz. does anyone know how to modify it? or can someone help me out w designing one? I have had quite a bit of experience with installing before but this will be my first box build.
There are plenty of designers on here that can get you a good design. I went with IonSQL to design my Fisher Custom box.
Chris is really good with designs, try pm'ing him, he is very active on the forums so it shouldnt be to long before you get a response.
the 32 hertz would be fine as well, just depends on your taste
27 is pretty **** low tuning
its not a bad thing, but its likely you wouldn't notice a big difference
i think ill build that box then. one more question.. ive never had a ported box before, does it matter where the port fire towards? ie. it i face it forward towards the back of the seat? or does it have to be fired into the rear? and what if i had the sub facing the forward and the port facing the rear?
its different for every car, just play around with it
when i called treo when i had my ssi ten they told me to put it in 1.75 net tuned to 35hz with 20 sq inches of port. it sucked though. i hated it. deff go smaller and lower.
skeleto
skeleto
los angeles
tcguy85
