Torn Surround Rainbow SLC 6.5"
Like I said, Plyabond. It's industrial strength rubber cement. It will hold up under repeated excursion cycles and will withstand the heat and cold of being in your door.
Black tape. //content.invisioncic.com/y282845/emoticons/furious.gif.fc81ca146dbff91fede3ed290dbc4f4c.gif
I actually took some silicone caulk to the top and underside of it.
http://img25.imageshack.us/img25/8585/dscn3205u.jpg
After it dried I pressed on the cone a bit to make sure I was getting good movement from the surround and to make sure the crack wasn't redeveloping and so far everything seems to be working fine.
I think the whole may be from a slipped drill or something when I originally put the speakers in over a year ago.
I did really put excess caulk on there, it wasn't a straight tear, it was only straight across the surrounds but broke off in opposite direction at the ends, so I pretty much squared the area.
Haha, no it isn't pretty. I played around my maxing the excursion out on the subwoofer with my hand to see how well it would hold up. The slope of the surround is still retained, the cracks are no longer apparent at all even when the surround is moving, "should" work just fine.
Trepkos
Trepkos
Mississippi
Trepkos
