Glue: Titebond glues only. Elmer's carpenter glue is just okay, but I personally prefer titebond II. They make I, II and III. Titebond I is the weakest of the three, though it cleans up easily with water and a paper towel. I only use this when I'm doing a budget enclosure, or something so small that the loss in tensile strength won't be critical. Titebond II has the best of both worlds of the three. It dries fairly quick (not as fast as I though), has decent cleanup, and is ****ing strong. I use it almost exclusively unless I have to make either a large ported box with minimal bracing, or as I said before, a cheap enclosure. Titebond III is the strongest glue they make, but it comes at a cost, literally, and figuratively. It's literally over twice the cost of the first two, and dries up about as slow as a swimming pool left open in the spring. I use this glue ONLY when I don't have a timeline, or if the enclosure is going to be for extremely high SPL subs, or the box has minimal bracing. For your box, II is the best, and I swear by it. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Screws: Grip-Rite coarse thread drywall screws, or their PrimeGuard screws. Both 1 5/8" lengths. If you aren't familiar with building a box, then you should probably start out with 1 1/4" so that you don't split the wood. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Carpeting (if you are): Do NOT buy carpet with a backing to it. It doesn't stretch or mold well, and is an overall waste of money. Get the stretchy stuff at
PartsExpress.com (2nd page of carpeting/veneer). To glue it to the box, use 3M 77 or 90 spray adhesive. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
General Construction: Pre-drill every screwhole. Make sure that you don't drill in more than 2.5" from the end of any panel, especially on the front baffle. You risk splitting the wood doing that. Before you screw, lay down a nice bead of the glue (don't be dainty with it, as it's what actually holds the box together. Screws are used to act as clamps while the glue dries), then clamp the two panels together, and then drill and screw. Beyond that, it's all good. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
If nothing else, take your time, and be proud of whatever you make //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
