I have a few budies that own a shop, that can tune my engine more for better results out of the spray. as for my ******, it runs great. The car runs flawless.Spray it and have fun. I've run that shit on most cars I've owned and NEVER had a problem. Just don't go crazy HP wise and you'll be fine. 75-100 should be about right and add plenty of torque to get that big car moving. How is the ****** in that car?
Technically he's right. Sure you can make the crown vic a quicker car, but its gonna take alot of money. But it will be a fun car to **** around with people with the nitrous.Why is that? My engine can be tuned, on a side note, its the same motor as the mustang gt...
yes they do crack and depending on the year there is a TSB out. my uncle has one and his broke and ford replaced it paid for his hotel and food. he know has a aluminum intake.the 4.6L cant handle spray very good, they have a plastic intake, spray and plastic=BAD
aluminum //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif The crossover is what cracks on the plastic intake manifolds. Ford gives you another plastic IM, but it has an aluminum crossover to stop it from cracking again.yes they do crack and depending on the year there is a TSB out. my uncle has one and his broke and ford replaced it paid for his hotel and food. he know has a aluminum intake.
My intake is plastic and I'm spraying 150-175 shot. Look at all the motors that use plastic intakes and people spray and boost on them. Plastic is fine.the 4.6L cant handle spray very good, they have a plastic intake, spray and plastic=BAD
Wrong car homie.Nah, Will do later, right now im more focused on speed.
50 shots can wake up a car quite a bit. I don't know where you work, but saying a 50 shot is a waste, is an uninformed statement. On a ****ing Vic it won't do shit, but strap a 50 shot in a civic and tell me it doesn't make a difference. The kind of car I have is known to reliably take a 100 shot, with no tuning, and last tens of thousands of miles that way, if not hundreds of thousands, with regular use of the spray. If you've got the fuel for it, and the proper plugs, you should be ok with a small shot. Most cars can't take a 100 shot with no tuning, but I don't see a 50 or 75 shot giving you any trouble, if you treat it right.It does not matter if the intake is plastic. The intake will go or you may blow the heads right off the block. If a motor is not made / set up for spray, do not do it. We build motors for spray, and lots of it. Those 50 shot kits are useless and can only lead to trouble.
