Tma 1000.1
how would i connect all 4 wires to the sub thru the box if i got that amp?
It's a class b so a little power hungry compared to a class d. Just make sure you have big 3, a good battery and 4 ga power and ground. A second battery really wouldn't hurt to keep the volts up. It is very hard to maintain 14.4 volts, especially with a class b that is power hungry. Overall it is not a bad amp. They are very quick to clip since they are power hungry and drop voltage on a stock vehicle quite a bit more than a lot of class d amps. If it were mine and I planned to stick with the single l7. Or a comparable sub for that matter. I would just upgrade the electrical and not worry about another amp. If you intend to upgrade your sub or go with multiples, I would look for another amp. The one you have is more of a sq oriented amp and also needs optimal conditions to make rated power. As for mid price recommendation, AUDIOPIPE 3000W AMP 1 CHAN CAR MONO CLASS-D AMPLIFIER - eBay (item 360276357153 end time Jan-23-11 14:54:53 PST) a very flexible amp. On your dual 4 ohm coil. You can just run it as a 2 ch, 1 to each coil for 1200 rms. Later on it can be ran at 1 channel on a better sub, or multiples. If you are happy with your sub disregard and save the money by staying with what you have. If you are not happy, odds are it is the sub. Although power hungry that amp puts out cleaner power than a lot of the sq oriented brands. It is just hard to put it in an spl role without a very good electrical system.
Good luck.
i have a 4 ohm L7 15" can i hook it up to a 2CH amp?
Yes you can. Ideally you'd want to bridge it in that case and not many amps available are stable at 2 ohms while bridged. Not to mention, not many 2 channel amps are class D which is what this whole thread turned into trying to teach you. Short answer, yes. Ideal? No.
and should i look into capacitors
No.
Really? Firstly, you don't need an amp that big. You'll want something smaller. You could use binding posts or a drill to get all 4 wires trough if you chose to go that route.
My honest opinion, start reading. You have lots to learn before you spend any more money. Bugflipper also has learning to do prior to recommending equipment to a newb that's bound to end sadly because you don't know enough to control that power.
what would you recommend?
No.
"Technical Specification RMS Power Range : 500-1000 Watts Number Of Channels: 1 Low Frequency response: 10 Hz High Frequency Response: 160 Hz Built In Crossovers: Yes Channel Separation: Yes Features Monoblock Subwoofer Amplifier MOSFET (Class D) Rated Power 14.5 V: 500W x 1 @ 4 ohm Rated Power 14.5 V: 750W x 1 @ 2 ohm Rated Power 14.5 V: 1000W x 1 @ 1 ohm High-Efficiency Class D Design Inputs: One Stereo Pair (RCA Low-Level) Input Sensitivity : 200m - V - 4V Preamp Output : Pass-through type with unity gain Frequency Response: 10 Hz - 160 Hz +/- 0.5 d - B Bandwidth: 14.57"" x 9.69"" x 1.93"" Dimensions (L x W x H): 14.57"" x 9.69"" x 1.93"" Low-Pass Filter: 12d - B/octave with continuously variable cutoff frequency selection from 40 Hz - 130 Hz Subsonic Filter: 24d - B/octave with continuously variable cutoff frequency selection from 15 Hz - 50 Hz Variable EQ-Bass Boost: 0 - +18d - B @ 45 Hz Phase Switch: 0 or 180 deg. Remote Gain Control Included A JL Audio Company" it is a class d amp and does have a SS filter....
ktwagner
ktwagner
Novato, California, United States
ktwagner
BP1Fanatic
BP1Fanatic
