Tires
jdawg90
my car has 195/60/15 tires. The ones on it are touring tempest hr 195/60/15. The fronts have atleast 70% and are wearing evenly. The back right is bald on the inside (low pressure) and has flat spots. The back left has flat spots but not nearly as bad. (yeah I was being a ******* with the handbrake). I'm gonna replace both back tires. Should I get the same type or go for something better? Can rotating two different types of tires cause any issues? I just want to get new backs and have the set of 4 last for as long as I can, when they are done I will just get a new set of 4.
Advice?
Any reccomendations?
One of the backs is shot and the other isn't looking that good. I just want to replace both of the worn tires so that I have a set of tires that will last me a while. If I just replaced the one that is fucked, it the other back tire would need to be replaced when the other 3 would be in good shape.
If I replace both bad tires, I will have 2 new tires and 2 with 70+%. I'd like to have a set of tires that will last a while, and when it's time for new ones, I'll just get a set of 4. As opposed to replacing them as they wear out. The fronts should last a long time, so if I replace both backs, it should be a while before I need a new set. I don't want to just be replacing individual tires as they wear out.
That being said, I would move the 2 back tires that were replaced to the front and move the fronts that are in good condition to the back.
jdawg90
jdawg90
alberta
xShoWTeKx
