Tired of my L7s
U n r e a L
im tired of my 2 12 kicker L7s and am about ready to jus call it a day and get a 13.5 w7....i have a one channel amp that is one ohm stable....so what ohm w7 will i need to get to run it down to one ohm...this will be my first single sub setup and i dont know how to figure out the ohm thing..//content.invisioncic.com/y282845/emoticons/*******.gif.a649d21efc0d1fd4890a6428166586c1.gif
The dub7 will wire down to .75 ohms, or 3 ohms. Most 1 ohm stable amps ought to be good at .75.
I'm biting my tongue on the dub7, though. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
so i will be able to run the 13.5 w7 to my 1ohm amp at .75? will that be more dangerous for my amp ? //content.invisioncic.com/y282845/emoticons/wow.gif.23d729408e9177caa2a0ed6a2ba6588e.gif i have a Audiobahn A1500hct btw
yea im gettn tired of blabbbed out spl and want some cleaner bass ...
if anyone has some kick *** single w7 13.5 box setups you will be the shit...lemme know...i want ported //content.invisioncic.com/y282845/emoticons/fro.gif.c695f1f814b01c4ad99fe7f8cccadd29.gif
Sell me your l7's //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif Pm me if interested in selling!
-Jon
Yeah, because of impedance rise, your amp will be seeing a load greater than .75 ohms. You shouldn't have to worry.
500 watts x 1 @ 4 ohms mono
1000 watts x 1 @ 2 ohms mono
2000 watts x 1 @ 1 ohm mono
Variable Phase control: 0 - 180
Bridging Module Compatible
Dimensions: 3.5"(H) x 12"(W) x 24"(D)
High Current Circuitry
PWM MOSFET Power Supply
Double Sided Glass Epoxy Circuit Board
S/N Ratio: >100dB
Frequency Response: 10Hz - 40KHz ( 1dB)
Remote Bass Control With Blue Backlight Knobs
Variable 24dB High-pass Crossover: 90Hz - 750Hz
Variable 24dB Lo-pass Crossover: 30Hz - 120Hz
Variable Subsonic Filter: 20Hz to 45Hz
Variable Bass Boost: 0 - 18dB
Variable Bass Boost Frequency: 40Hz - 100Hz
RCA Throughput Connections
4-way Protection, Circuitry: Thermal, Short Circuit, Overload, and DC Offset
Dual Cooling Fans
VU Meters Indicating Output Response
Cobalt Blue Illumination
High Gloss Chrome Plated Finish
Chrome Plated Flame Design
Nickel Plated Block Terminals
it says it does....and it pushes both my l7s like its nothin....only audiobahn product i will ever buy is this amp...everything else is doo-doo
I highly doubt that the amp is producing 2k,I seen inside the 2300hct,lol.For bang for the buck check hifonics of power acoutik,I just so happen to have a Pa3000d that I am willing to sell if u are interested.Also look around the classifieds for a kicker 1500.1 or soemthing,
U n r e a L
U n r e a L
Matoaca -VA-
BMW Sidewayz
