Tint question
If you are visiting a state that doesn't allow darker tint percentages than what you have, you can usually slide by on a tecnicality if you get pulled over. But since Michigan allows any percentage and North Carolina is 35% max, stick with what MI will alot you. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
I recommend SunGard Endurance film. Awesome stuff. But, what kind of vehicle, what color, and do you use or plan to use satellite radio?
I'm going for Lumar. Used to work with a guy who did it and that stuff kicks ***! Maxima GLE with Black is what im shooting for. I have Sat radio with the antenna mounted externally in front of my sun roof. Do you for see a problem?
Got a qoute for $175 from one place, need to do some more research. Thanks!
I agree Lumar is pretty good stuff. As for the Sat radio... if you plan on going with a fully metallized film, it can cause some reception issues with Sat radio, just so you know.
Even if the antenna is outside of the front windshield???
Appreciate the help man.
If it's outside, you should have no problems then. And that enables you to get the fully metallized film and not worry about it turning purple on you or degrading in color after 2-5 years in the sunlight. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Mynameismcgyver
Buford T. Justice
Mynameismcgyver
Long Island, Ny
Mynameismcgyver
