Sold Time for a change sale SUNDOWN 1500's/IA Death row 12's
TeamXDMatt
ok guys i'm changing to a more simple setup so all of this needs to go.
First up are my 3 Sundown 1500d's new heatsink.. only seen 7 shows in excellent shape just might be a couple of scratches in the sundown logo on the amp when i had a plexi glass display over them. i have all the boxes and bass knobs for them. $325 each shipped .
SPECIFICATIONS:
* Double Sided Through Hole Epoxy PCB
* Efficiency : 86% @ 4 ohm, at 100Hz
* 24dB/Oct Variable Crossover
* Multi-Way Protection Circuitry
* (Thermal/Over Current/Speaker Short/Speaker DC Protection)
* Variable Subsonic Filter
* Variable Bass Boost
* Variable Low Pass Filter
* Variable Phase Shift
* Zero(0) Gauge Power Supply Connectors
* Tested Voltage & THD : 14.4V & Less than 1% THD
* Operating Voltage : DC 10V~18V
* Digital Class-D Linkable Mono Block Amplifier
* 1 Ohm Stability
* RCA Line Input and Master Output
* 24dB Octave Crossover Slope
* Wired Remote Controller
* MSRP $799 USD
Rated power output
----RMS power, 2 ohm linkable/dual mono
3000W x 1CH
----RMS power, 1 ohm mono
1500W x 1CH
----RMS power, 2 ohm mono 800W x 1CH
----RMS power, 4 ohm mono
400W x 1CH
Signal to Noise Ratio >90dB
Low pass frequency crossover 35Hz~300Hz
Subsonic filter 10Hz~60Hz
Bass boost @ 45Hz 0~18dB
Phase shift control 0~180 degree
Frequency response 10Hz~350Hz (+/- 1dB)
T.H.D @ 4 ohm
Efficiency @ 4 ohm 86%
Fuse rating 40A x 4
Input Sensitivity 200mV to 6V (+/- 5%)
Dimensions 252(W) x 58(H) x 434(L)mm
2nd is 4 Incriminator Audio Death Row 12's Dual 2's. 2 have already been sold.. all the coils read fine one of them is rubbing a little bit since i had it reconed but i haven't had any problems with it. i have put over their rated 1000 rms to them since i switched to a 16v setup. nick says about 1500rms is about tops for these.
$180 shipped
$160 shipped for the one thats rubbing but i havent had a problem with it.
Features include:
• 8 spoke black cast basket
• 3” 4 layer flat wound aluminum voice coil
• Double Black Progressive Spiders with Woven Tinsels
• Injected Pulp Matrix Fiber Reinforced Cone
• Double Layer Foam Surround
• Triple Stacked Magnets with Black Nickel Finish
• Interlocking Aluminum Spider Spacer Assembly
• CILD - Center Interlocking Dustcap
• ADC - Air Driven Cooling
• Nickel Plated Push Terminals
• Wrap Around Rubber Gasket
• 1000 Watt RMS Rated
havent really messed with any of those. the show i went to last weekend i was only using 4 of these and started out at a 152.9 in bass boxing they are definitely a good sub i'm just going down to 2 18's now to make things simple.. also i don't really have enough airspace for all 6
i've had them for over a year now just havent made it to many shows. don't think they are under warranty now. i've never had a problem with them. was running them at .7 on 16v and never had a problem
TeamXDMatt
TeamXDMatt
sanford, florida
TeamXDMatt
