Three (3) Digital Designs DD M2a amplifiers - 3 Beasts for only $1000!
Mike Waters
All in perfect working order.
Cosmetic condition of the first 2 of them would be a 9.5 out of 10 only very minor marks around the mounting holes from it being screwed down.
Cosmetic condition of the 3rd would be an 8 due to the one scratch on the top (pictured).
These Beasts are .25 stable and push some MAD power, you can also strap these! Here's a little info on these from a debate over the DD M2a or the AQ2200D-
DD M2a Vs AQ2200D 1000$ VS. 500$ your choice
Apples to oranges guys. The m2a can run at .25ohm daily the aq cannot. The DD will keep on kicking even with voltage as low as 10v the aq will go into protect well before then. The m2a is meant to be run at low loads at .025 - .5ohm the m2a's do some serious power and really come to life down low. I would take a m2a over an 2200 any day and anyone that does some simple research would also choose the m2a. FYI I run a aq2200 and love it but it does not like low voltage and does not really perform very well at low loads daily. Yes, I know u can run a 2200 at.5ohm but after rise amps prob seeing well above a 1.5ohm load. The 2200 will not run for much longer then a burp on a tru .5ohm load. Plus the difference in power it produces in .5 is not a massive difference then what it produces at 1ohm. The DD is the total opposite the lower the load the more she smiles check out some bench test on soundpressure on the m2a the difference in power it produces at 1ohm vs .5ohm just seems impossible. I run aq because I can’t afford DD no reason to lie. Yes, same build house but totally different parts DD spares no expense AQ has to go with lesser components to keep the price down. Cadence uses the same build house and the same board’s only difference is the parts they use and the badge on the top.
$1000 shipped for all three (3)
Shipping and Miscellaneous Item Information:[
shipped free within the states
Feel free to text or call if you have any questions or concerns (904) 307-9063 Thanks, Mike.
You are shitting on this forum by spewing bullshit about amps that don't need bullshit spewed to sell them.
Nothing that guy wrote is true excpet the buildhouse comments.
Here's my personal clamps of an AQ2200.
AQ2200
- .25 nomnial rising to .9 ohms
- 2,538w @ 11.4v
- 3,365w @ 13v
You have personal clamps of the M2a better than those? And I never said it couldn't run .5 daily. Also didn't say it wouldn't do 2k.
I try not to reply in people's FS threads, but come on. There's no need to make shit up to sell these amps or copy and paste someone's biased and erroneous opinion of them.
Well d@mn..... kind of makes me want one to run at .5 lol
Mike Waters
Mike Waters
Middleburg, Florida
bgowdy
