this *****!!!
vibe
got my hdd 12s in my car with my saz 5000 everything wired up 3 d3100 batts in the back 3 runs of 0 gauge sky high for power and 3 for ground big 3 done. got everything wired up and 3 days after my mechman 240a alt takes a **** on me. the voltage was at 13.6 when this happened too. dont get why it did this. it was even acting goofy when i had my 2 kicker comp r 12s on my brutus. wasnt holding voltage. hoping mechman will make this right. its only 5 months or so old. weird thing is i put my stock alt back in which is a 90a and the voltage is higher and holds **** near as good as my mechman would. granted im not going to push it but thats the weirdest thing for me
Before you rule out the ALT shot, unhook your batteries and charge and check them one by one. I had a isssue to mine doing this, a guy told me to unhook all my batts and check all voltages by them selves, and i did it and one them were shot. it was pulling down the voltage so bad, it was acting as a load on the alt. I removed it and hooked the others back up and it was fine, havnt had a issue since.
---------- Post added at 05:38 PM ---------- Previous post was at 05:37 PM ----------
the wheel on the alt is literally locked up and it shredded the shiet out of my belt
oh never mind, i didnt see this before... its def the alt
Wow, that *****. They should make that right for you, but concerning the belt I doubt they'll do anything about that.
the belt had a warranty too so i got that replace but yeah it ***** man. they better make it right. still think im going to go with a singer 320a 6 stage hairpin and regualte it to 15v or i may get a ohio generators alt. not sure yet
My mechman has messed up 2 times in under 2 years ..im about to send it back monday ..sux ..but yea the alt only does like 140 at idle i bet u hold vetter voltage while driving bc that alt doesnt make full power until 1500rms
Are you gonna run an external regulator?
yeah. 15 volts. i actually almost have to man it *****. i have a 98 lexus es 300. and the computer system on it is fcukin pain in my butt. it wont let my alt charge worth a ****. the highest my mechman could go was 14.1 completely cold. my stock alt goes to 14.3.
---------- Post added at 03:03 PM ---------- Previous post was at 03:02 PM ----------
2000 for mine. n shuldnt it give out full power at 2k in park too? cause it dont
vibe
vibe
Prescott, AZ
momofx
