You may want to consider 2g or larger (1/0 is the norm above 4g). With 100 amps you're pushing the upper limits of 4g without increased resistance, especially if your run will be 15 + feet long (granted your amp won't typically, if ever, pull that much). 1/0 will also allow you to easily add that 2nd amp for your components when you realize you need it //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
What subs are you running and what voice coil/ohm?
