This is alot of 18" Nightshades
Sounds almost the SAME as what Scott and the guys do at Fi with there BP Power plug //content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif
Imitation, is the greatest form of flattery.
Alot of good ideas, just build off each other in terms of engineering, you've apparently never compared the DD9500 cooling to the BTL cooling....If you would have then Scott copied Jess and the madness continues on.....
So in a sense we all copy each other, but to each is own! //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
No big deal, really... you see plenty of companies doing gap venting now too but not everyone storms out and says they are imitating Atomic.
There is a demand for high powered speakers - and air flow over the coil is a great way to provide it. There are only so many ways to do it.
Scott / Fi also use their Axial channels too, by the way - which is a great idea too, IMO //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif I think it is patented, though - I see Nick in here, I'm sure he could say.
//content.invisioncic.com/y282845/emoticons/thankyou.gif.5451126d09e870f796f50c3a4dd5acd7.gif
ps/fyi, Mr. Wu has a patent on those holes in the back plate.
Negative ghost rider, pattern is full.
Don't do cross drilling..don't have pole vents..dont do the top plate thingy they do...
*shrugs*
A good idea is a good idea.
Why so uptight ?
Good idea, which is simply not your own.
So your motor gets no other work with the 'pole option' just a straight bolt on arrangement?
Hope its not the case //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Mr_Singh,
It works quite well, thanks. Do the axial channels from Fi provide additional benefits - absolutely, I'm not saying they don't - but it works quite well for us this way.
With the 6-spoke basket we add spacers under the frame so you have a path for air exchange, if that is what you are asking.
No need to be so negative - I have no problems with Scott and Nick @ Fi and I am sure they have no problems with me.
Mr_Singh,
But you didnt answer the question.
sundownz
Pro Seller
Supporting Vendor
sundownz
North Carolina
Lil Poot
