this ****ing kenwood
thanks mld, but i have the manual already. i can set everything else except the subwoofer level/volume and the LPF. it seems like the HU skips over those when setting everything else. idk why. i'm guessing, therefore, that there must be an on/off option for the sub
found this on crutchfield:
Low-Pass Filter: The receiver features a built-in Low Pass Filter control for the preamp-output when the Subwoofer Output is "on". You can select from 50, 60, 80, 100,120Hz or Through. The "Through" setting allows your external amplifier's crossover network to do all the filtering for your subwoofer.
Subwoofer Level: Once you have switched the Subwoofer Output to "on" you can independently control the subwoofer preamp output level from the CD receiver. You select levels between -15 to +15.
Subwoofer Phase: You can adjust the phase of the subwoofer output between 180-degrees (Reverse) or 0-degrees (Normal).
how in the fuk do i switch this on!?!?!??!
adio
THE STEREOTYPE FIGHTER!!!
adio
college park, ga
Macklessdaddy
Mike Mccabe
