This amp have enough power?
geowick07
Those CVRs are rated for 400w each. I reckon they'll safely take around 500w easy. So a kilowatt worth of amplifier ought to serve pretty well //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
For listening to music at a sane level that amp will be more than enough. Contrary to what many people o this forum would have you believe, you don't HAVE to have on tap every ounce of power that a sub can handle. Wire each sub in series for an 8 ohm load and then wire the subs in parallel for a 4 ohm final load and bridge the amp.
You could for about the same money get a smallish Class D with the same or a little more power that would be more efficient...
geowick07
geowick07
Warren, Michigan, United States
helotaxi
