prabhakarglv
Hi,
I installed Power Acoustik PNX-761 after market radio along with Axxess ASWC-1 steering wheel interface module in my 2006 Honda Element M/T today. I also installed toggle switch to bypass the video for my kids while driving the car.
When I drove the car today I encountered the following issues,
1. Steering wheel controls are not working though the module programmed correctly as per the instruction manual. But the controls on the radio is fine. I called Axxess technical support team this morning and they I programmed the module correctly, but they suggested me to program in after market radio for steering wheel controls. I checked the settings section in my radio, but I didn't find anything in regard to steering wheel control. I also checked the manual of the radio thoroughly, but none I find in regard to steering wheel control programming in radio. I'll call the Power Acoustik Technical support team tomorrow for this problem.
2. I was able to bypass the video successfully using toggle switch, however while I was driving the car today I noticed if I use Navigation or Video or BT Music and in all circumstances WITH THE LEFT TURN SIGNAL ON, the audio volume of the radio get increases automatically without I'm pressing the volume button of radio. With the right turn signal ON or if the car is in parking mode or if it's running straight without any turn signals ON, I don't have any issues. I searched in google about this issue to find the solution, but found no success. As far as I concerned I didn't made any errors in wiring connections as per the manual.
I would appreciate your help for the above regard.
Thank you,
Pubby.
Thank you,
Pubby.
