THE Thread
Masturbating with **** Rings
**** rings are devices that encircle the penis, fitting either at the base of the **** or around the penis and testicles. They may be adjustable straps of leather or cloth with fasteners, or solid rings of rubber or metal. Although **** rings may have connotations of bondage or sado-masochism, using one does not have to be painful or even uncomfortable. Most often, men use them to enhance their erections or pleasure during *** or ************. You don't have to be kinky to experiment with **** rings.
Leather **** Rings
The big squeeze
**** rings work by restricting the flow of blood out of the penis, keeping it engorged. The vessels that bring blood into the penis during erection are farther from the surface than the veins that carry blood away. The **** ring exerts pressure on the surface vessels. This doesn't cut off the blood circulation to your dick, but slows it down, meaning you get a bigger, harder erection that can last longer.
Additionally, if a **** ring also encircles the base of the penis and the scrotum, it will put pressure on the perineum, the area of skin between your balls and *******. This in itself can be pleasurable, but it may also put pressure on the vas deferens, which carries sperm to the penis, thereby delaying ejaculation. This can give you extra time to stroke off and create a buildup to a truly explosive orgasm.
Order **** Rings
How do I put it on?
Most adjustable **** rings are designed to encircle the balls and penis. These rings are the easiest to put on, because all you have to do is wrap them around your **** and/or balls, and fasten the snap or Velcro closure. This can be a little tricky at first, but like fastening a wrist watch with one hand, you'll get the hang of it. While your dick is still soft, grab your whole package in one hand so you're lifting and holding your balls against the underside of your dick. Position the **** ring at the base of the balls and hold it in place by encircling it with your thumb and fingers. Then release your dick and fasten the closure with your free hand. Make sure it's not on too tight and you don't pinch anything when you close it. Position the closure wherever it feels most comfortable.
Putting on a solid metal or rubber **** ring is a bit trickier. First grab the loose skin of your scrotum and pull it through the **** ring, then pull or push your balls through the ring. Press the ring up to make space at the top, then push your soft dick through and adjust the ring by pulling it back towards you. To remove a solid ring, repeat this procedure in reverse. Your dick must be soft to either put on or remove a solid **** ring.
Stretchy **** rings of jelly rubber or silicone that fit around the base of the **** but not the balls are easiest to put on if your dick is at least semi-erect. Although they may look too small to fit over your ****, they stretch a lot and can easily accommodate many sizes. These types of **** rings often have a small vibrator in them, which can be used for clitoral stimulation of a partner during intercourse, but is also fun to turn on to add some buzz to your ******** session.
Once it's on
Once you've succeeded in getting into your **** ring, what should you do? Start stroking and see what happens. You may find yourself getting one of the biggest boners of your life. Don't forget to check yourself out in the mirror, because **** rings, especially the leather ones, look cool and enhance the appearance of any man's penis.
Some guys get so turned on by wearing a **** ring that they shoot almost immediately from the excitement, while for others, it prolongs the erection and delays their ejaculation. If this is the case, you may want to draw your wanking out for an extended session, bring yourself close to climax and back off, then finish off with a big bang. If you have an adjustable **** ring, undoing the fastener and removing it near the moment of climax can bring explosive results. Is it safe?
Because **** rings restrict the blood flow to a very precious part of your anatomy, some caution needs to be exercised when using them. **** rings should fit snugly, and have to be tight enough to be effective, but they should not cause pain or discoloration of the flesh, or bite into your skin. Use extra care when using solid **** rings and don't attempt to wear a size that is too small for you. They come in a range of sizes, so get one that fits.
Order **** Rings
In general, you shouldn't leave a **** ring on for more than 30 minutes. Don't use Viagra in conjunction with a solid **** ring, because if you can't get soft you won't be able to get it off. Stretchy **** rings, even if they are comfortable, should not be left on for more than half an hour either. Although they are stretchy, they also exert constant pressure on the blood vessels, and your **** needs to breathe. If you are concerned about safety, be sure to get an adjustable ring or one with a quick release, so you can remove it easily if you think there is a problem.
Special effects
Some **** rings offer other enhancements, such as ball spreaders. While we don't know if these enhance the ring's functionality, they do look and feel hot. Other **** ring features, like flashing lights or glow-in-the-dark material, definitely don't enhance a ring's effectiveness, but are fun nonetheless. Vibrating **** rings, on the other hand, can be stimulating to wear for both you and your ****** partners.
Will it make me bigger?
Wearing a **** ring will not increase your penis size, at least not permanently. Some uses report that their erections with a **** ring seem longer and harder than normal. This can be accounted for by the extra blood being held in the member. However, even prolong and repeated use of a **** ring will not enlarge the penis permanently. Although **** rings may help some people who have difficulty getting or staying hard, they will also not cure erectile dysfunction, Wearing a **** ring will also not automatically turn you into a stud or a fantastic lover, but feeling good about your dick and having an enhanced erection may inspire you to reach new heights.
How many women have you de-virginized? //content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif
Me: none //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
Always wanted too though...
I dunno, women lie about it too much //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif Lets guess 4 //content.invisioncic.com/y282845/emoticons/ponder.gif.ec2527b23f1d287b60dcbba54f95edba.gif
its not always good. expirience is better. at least to me.
RangerMan
Premium Member
Premium Member
RangerMan
NC
x2o
BP1Fanatic
BP1Fanatic
