THE Thread
no what doesnt?
I hope your not talking bout the bp1200.1 because I can tell you exact what it says in the book
1200x1@2ohms
600x1@4ohms
1ohm stable.
As for the lanzar I have no clue. I cant seem to get specs on the lanzar anyway. So maybe I will go with 2 lanzar d2000m and run them both at a 1ohm load or get the usx1000d and run them 1ohm.
Originally posted by Jeremy jl fan Where did you get the specs to prove this? Im not saying I dont believe you, but I would like to take a look at the specs on it? The most info I got was 3000@1ohm mono
yea its pretty shady...i dont have the box but i think that its around 2500 RMS (i dont even think it says on the box) @ 1ohm. its 900 watts @ 4ohms...not sure what it is at 2.
-nate
Originally posted by Jeremy jl fan Ok wonder, but I was just going off what the jbl said, because it does 1200 at 2ohms and 1ohm....would it be able to find out what the d3000m does at 2ohms?
very close to 2000 watts RMS @ 1ohm....so im guessing ~1000 @ 2ohms...this info is from dreid.
-nate
Dimensions: 13.8” (W) x 2.3” (H) x 16.7” (L)
Well if it only does 1000rms at 2ohms then its a waste of money and time to buy one when I need 1200rms per sub. Lol man such a hard decision.
I could get a pair of lanzar d2000m and run them at a 1ohm load.
Get a pair of usx1000d and run them at a 1ohm load.
Or get another jbl bp1200.1 and run them both at a 1ohm load.
I may be wrong, but cant you run a single dvc 2ohm sub at a 1ohm load?
Thanks for all the help.
Originally posted by Jeremy jl fan I may be wrong, but cant you run a single dvc 2ohm sub at a 1ohm load?
nope...just a dvc 2ohm. unless you are running an amp that is not mono...im kind of shady on the wiring for stereo etc...
any of those lanzar rack amps are still a great buy...you wont find an amp that cheap that puts out around 1000 watts @ 2ohms.
-nate
Wy don't people paint subs diffrent colors.//content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif
That would be so tight, i'm pretty sure you could make some money off of it too, because no one would know what sub you had, and you could be like yea well i bought this from over sees thats y it's colored it cost about a half a million pounds, but hey i said what the hell...
RangerMan
Premium Member
Premium Member
RangerMan
NC
x2o
vegang
vegang
