The Teardown......and rebuild - everything but the box
Edit: (just wanted to make sure you saw what I originally posted) Robin, instead of airlines (unless they will be medium/high pressure) I recommend 4" pipe from a dryer, because those air lines will never supply enough cool air to cool off your amps. The only thing that might be feasible with small lines is water cooling with a radiator on the front of your car for the amps only!
Oh and lmfao.....
fail.
fail.
fail.
fail.
fail.
fail.
fail.
fail.
fail.
fail.
fail.
fail.
fail.
fail.
fail.
fail.
fail.
fail.
fail.
fail.
fail.
fail.
fail.
i bet that took awhile.....lol
it was an idea to cut into the A/C and use those lines to run cool air to the back, and have fans for the amps
i scrapped the cool air idea, and i will just use 4-8 120MM 12v fans to keep airflow
there are some new pics
i really wish i had done some before and after pics, to see waht i started with, but i will get pics of the bare box (backside) tomorrow evening
here is a pic of the trim panel that i made to cover the remaining portion of the trunk floor, and its where the batteries will sit.
I made it using 1/4 inch HDF that i picked up from a friend
idk what that light spot is in the middle, because i sure cant see it in person.
oh well.....might be dirty
a part of the wiring tha ti had to tap into to relocate the switches to the middle dash....
a sample of whats going on in the car now
a fucking disaster. I have the wires pretty much mapped out as where i want everyting to go
that black carpet is what i am going to be using throughout the entire car./
every surface that gets carpet, is getting that thick jet black carpet
its really thick, and hard to work with around corners, so hopefully w can kep them to a minimum
Thanks tapout, I appriciate that
Chris, Wanna come out on Sunday? - thats when i plan to get as much as possible done, because i think im driving it to the shop to get the roof repaired monday, and itll be gone for a week or two
Backside is still a mess
but i love these batteries
wiring done for the switches
Wire management at its finest
so far i have got all the wiring set up (just about)
iamamp3pimp
Bass Heads Entertainment
iamamp3pimp
Tampa FL
PHAT BOi
