the solution eludes me...
Flyer
I have 2 15 eclipse ti's I have the voice coils hooked up in parallel and the subs hooked up in a series to the jl 1000.1 amp at a final 4 ohm load. Just noticed today that one of the subs is not working. There isn't a break in any connection because one sub still works. I used a ohm meter and both subs register at 2 ohms. If a sub is blown, will it still give a good ohm reading? What else could it be?
Thanks
Flyer
Thank you, you were right one of the terminals on the sub are mis-marked from the manufacturer. The hole terminal is turned around backwards. I had it hooked up that way for a month and never even new that I only had one sub working. It is even more amazing now.
Thanks,
Flyer
Flyer
Flyer
Des Moines, Iowa
nissanrider06
