~*the Rebuild*~
kpozr2
okay so here it is. this is what i have to work with, im not changing a thing.
WIDTH- 38 3/4"
DEPTH- 15"
HEIGHT- 12"
this is the state of the box, sanded, wood filler is in.
id like ONE port, tuned to 36hz. it can be however wide...pref 3+"
im figuring 4.205 ft. for internal volume without the port. i want to fix this, ship out this box if Army-Killa still wants it, or else ill use it. now for port length.
12x4-------14.75" long gets me 37hz...is this correct? and where do i measure the port length. down the middle? inside the wall. or around the outside of the port wall?
ok so i punched some numbers...i really could use another opinion, sorry for bothering everyone.....
12"*4"*16"=768
768/1728=.444
4.202-.444=3.75^3 ft....that its about 1.8^3 ft per sub. not with driver displacement yet.....
yeah, you need to use net volume when calculating the tuning, so it's kind of a back and forth until you figure out what you want.
i don't think you can do better than 2.9 cu ft @ 36Hz with a 4"x 12" port.
here ya go:
http://www.subwoofertools.com/forum/ported-box.asp?Ew=40.25&Eh=13.5&Dia=5&Xmax=12.5&Vd=.1&NumW=2&Vb=2.9&Fb=36&Qts=&Vas=&Fs=&CE=0
EDIT: nevermind, i thought you were re-doing the other box too.
how long did you end up making the port?
(make sure you measure like this: port info )
or, to not confuse you, how long is the second part of the port wall (after the bend) ?
sorry i wasn't around this afternoon to help with the calculations, i was still at work //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
can't wait to hear your new and improved box (and mine!).
kpozr2
kpozr2
Iowa CIty, IA
kpozr2
