The Birthsheet/Benchtest Thread
Xtant 4180C
Battery Voltage: 11.79 Volts
Dummy Load Resistance: 3.9 Ohms
Amplifier Output Voltage: 15.04 Volts
Actual Power Ouput per Channel: 58.0 Watts
Rated Power Output per Channel: 45 watts
has soon has i take pics , ill post pics
kicker kx1200.1 1420@1ohm
kicker kx1200.1 1370@1ohm
kicker kx200.2 280 ohm wasnt listed so i think it would be at 2ohm
planet audio VX400D
tested 13.0 volts
bridged4ohm n/a
output 2ohm 600watts
1ohm n/a
signal 2 noise 100db
dampaning 400 @20 hz 4 ohms
thd(class d) 0.52% @ 10 hz-265hz
input sensitvity 101mv-8.0v
tested 11/3/05
Punch 150 Limited Edition //content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif
zachzchw
zachzchw
ohio
kr15
AJ (ACE)
    Jun 28, 2026
Mike Mccabe
    Jun 28, 2026
