The Birthsheet/Benchtest Thread
PG Tantrum 500.2.
Somewhere around here I have the one for the 1200.1...
Phoenix Gold Xenon 100.4
Sorry for the bad scan, cheap printer/scanner/copier. Basically says that it passed all of the bench tests, and does 490 with all 4 channels driven at 4 ohms.
alpine mrd m501 - 598.7 @ 2 ohm @ 14.4v
alpine mrd m501 - 594.1 @ 2 ohm @ 14.4v
dont have the capability of posting pics cause i use my work computer so your going to have to take my word for it:D
Can't post pics either because I currently use a WebTv unit, but I received my Kicker KX1200.1 this week and the Birth Sheet shows 1490w.
The sheet on my KX450.2 I got today shows 460w.
Orion 2500d wired to .5 on 17 volts
3300 watts RMS
I'd also like to add that most manufacturers actually use "max" power when they rate an amp... multiply ure birthsheet by .707 and your about what your actually getting.
Phoenix GOld MS1000
MS1000 SPECIFICATIONS:
Stable to 4 ohms bridged OR 2 ohm stereo *due to excess heat*
Into 4 ohms @ 12.5/14.4 VDC
250/340 WRMS x 4
Into 2 ohms @ 14.4 VDC
520 WRMS x 4
Bridged into 4 ohms @ 14.4 VDC
1060 WRMS x 2
Dimensions
34"L x 11.4"W x 2.4"H
----mine does 1320x1 one one side and 1288x1 one the other------not too shabby for a frontstage amp.
sub amp-----Revolution D1500.1
500x1@ 4ohm
950x1@2 ohm
and 1580x1@ 1ohm
zachzchw
zachzchw
ohio
kr15
AJ (ACE)
    Jun 28, 2026
