Termlab vs. TrueRTA
what are you looking to find out ?
diff in decibel reading between the two?
ease of use?
reliability?
My two cents is that the TL is a much better unit to measure SPL
Its more accurate, the chances of it malfunctioning is far far less than the AC units and
another key point is that its the most recognized measurement device used worldwide
now that I've taken a closer look at what this TrueRTA is.. it has nothing to do with SPL readings whatsoever so to compare it to the TL is pointless..
now if you wanted to compare the TL to something it would be an Audio Control RTA/SPL set up.. as for my opinion look at my previous post above //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Andrew_as
Andrew_as
Topeka, KS
DidUHearThat?
Mike Mccabe
