Sold Team Cactus 5Kw, 2 RD Alphamax 15s, 2 15s Ported Box
GearGuy2001
Just testing the water, want to do a new system that is smaller.
Team Cactus 5kw
$800 Shipped
It blew in august and was repaired by dB-r
Here is what Chris said
"It's done. I didn't find a transformer short, but I did silicone the wires coming off them to help prevent rubbing later on, it's a common failure mode. We beat on it good for about 30 minutes, 100-200 amps @ 12V and it never missed a beat. We did find 2 of the outputs that had broken legs, but weren't bad, so we changed them anyway. And did the soldering upgrade on the whole amp. I did find some exposed copper traces along the edge of the PCB where it slides into the slot inside the heatsink to hold the board in place and it could have been exposed/damaged from a previous repair. This could have shorted to the case and blew the power supply because it was the gate drive trace for that side of the amp that blew. I put Kapton tape all down the edges of the board before I reinstalled it so it won't happen again. That may be why the amp blew. Someone had worked on this amp before, maybe the factory or ARC or something... Also had to repalce a stripped speaker terminal. Be careful how tight you tighten those wires, the connectors on the amp are only made of pewter and strip really easy if you overtighten the screws."
It was only mounted on my box prior to repair, after repair I made an amp rack and have it sitting on rubber feet.
RD Alphamax 15s D2
$205+Shipping each
I have 2 and might be willing to seperate. These were ran at 1200w's all of their lives so they are in great condition. One has a nick on the surround.
2 15s Ported Box
$300
Local Pickup
Box is 40 wide x 23 deep x 22 high
Approx 9.1 Cubes (before port and sub displacement)
34-35Hz Tuning
Double Baffle Front, 45s in the rear, support for the segments of 6" PVC
Black Microfiber Suede
All Prices are Best Offer and Im open to trading for smaller subs/amps
Trade the Alphas for a fresh PSI reconed RE HC18? I can shoot you details and pics if you're interested
No Thanks, Would like to downsize
**** never even got to hear this setup, still going to try a bandpass some day?
Who knows, Maybe it wont sell and yes I may be doing a 4th or 6th order as my next setup.
willing to trade the cactus for a ddz2?? pm if your interested
Possibly, Shoot you a PM later today
GearGuy2001
GearGuy2001
South Beloit, IL
GearGuy2001
