Teach me
I'm stuck on these problems, can you tell me how to get the answer?
An air conditioning unit contains 2.38 kg of water at room temperature. If the specific heat of water is 4.186 J/gºC, how much heat does the water lose to cool down from 30ºC to 4ºC?
259.03 x 103 Joules
259.03 Joules
45.73 x 103 Joules
14.78 x 103 Joules
0.25903 Joules
200.0 Joules of heat is required to raise the temperature of an object sample by 3.00ºC. If the specific heat of the object is .01490 J/gºC, what is the mass of the sample in kilograms?
0.993 x 10-3 kg
4474.3 kg
4.474 kg
40.268 kg
0.067 kg
The specific heat of a special ceramic tile is 140,000 J/g°C. If 20.0 grams of this ceramic material had a temperature gain of 20°C, how much heat was absorbed by this material?
28,000 cal
56,000,000 Joules
48,000,00 Joules
None are correct.
A 2.00-kg metal object requires 5020 J of heat to raise its temperature from 20.0°C to 40.0°C. What is the specific heat capacity of the metal?
126 J/(kg • °C)
106 KJ/(kg • °C)
126 cal/(kg • °C)
142 kcal(kg • °C)
1146 joules of heat is released when a 100.0 gram sample of an unknown metal cools from 95.00°C to 65.00°C. Determine the specific heat of a metal.
0.755 J/g°C
1.22 J/g°C
.887 J/g°C
.3820 J/g°C
What is the fuel for the nuclear reaction in the sun?
What type of nuclear reaction takes place in a nuclear reactor?
This is simple I think, but I think I'm wrong..
Fuel for nuclear reaction... I don't know what fuels fusion, unless fusion is the answer
And I'm pretty sure fission occurs in the nuclear reactor
the reaction in the sun is the fusion of hydrogen. same with atomic bombs, they are also called hydrogen bombs
i dotn remeber what nuclear reactions are. i think they are fusion
A pot of water (2.5 Liters of water) initially at 25.0 degrees C is heated to boiling. How much energy is needed to heat the water? The density of water is 1 g/ml.
So 2.5L = 2500mL, which is 2500g in this equation, correct?
Boiling is 100 degrees C, so difference between them is 75 degrees, right?
So 75 = (x)(2500)(75)? Or no?
Kenny Pollock
drag it!
Kenny Pollock
Hollywood, Florida Low: Yes
Kenny Pollock
