Sold TC sounds DB500 Pair - $150 shipped
SPY
I still have a pair of 12" TC Sounds DB500's
SVC 4ohm
There is something else I want to buy so I'm selling these for $150 shipped, if the other item sells before these do they will go back to the original price of $150 + shipping.
Introduction
Never again will you find a better driver for less money! The all new dB-500, offers you the absolute most bang for your buck that we can possibly provide. This amazing entry driver shares many of the TC-1000's defining features including the beefy 135 ounce high performance motor, a high thermal four layer aluminum 2" voice coil, and up to 2” peak to peak excursion. This driver is built to last and we construct each with the same standards as our high end speakers. The dB-500 simply can’t matched for this modest price and best of all, we're still building this driver in house right here in San Diego California.
Specifications
Advanced FEA Motor System
• Double stacked 1" tall ferrite magnets and bored T-yoke for long throw
• 135oz top grade magnet structure
• Anti-flux modulation copper shorting ring to lower distortion (12" only)
• Low carbon steel used for the gap plate and t-yoke
• Pole vent for lower distortion and cooling capabilities.
Advanced high excursion soft part system
• High excursion 8.5" linear roll poly-cotton spider
• Intergraded woven leads to prevent lead-slap
• 2" diameter, 4-layer aluminum wire voice coil with an anodized aluminum former
• Single or dual 3.4Ω (4 ohm nominal) voice coil configuration
• Lightweight brushed and powder coated aluminum cone (12" only)
• 1" wide long throw, highly durable NBR surround
• High quality thermal flexible epoxies to ensure longevity
Performance
• Effective motor force of 50 Newtons2 per watt (BL2/Re)
• 400 watts continuous power (1000 watts peak)
• 20mm BL XMax (voice coil, one-way)
• 34mm XMech (mechanically limited, one-way)
12" dB-500 SVC
Qts 0.447
Qes 0.481
Qms 6.347
Fs 24Hz
Res 3.25Ω
Ls 2.36
Lp 3.51
Rp 2.91Ω
Dia 241mm
Vas 71.5l
mms 169g
cms 244um/M
bl 13.3Tm
Spl 86dB
1.4-2.8ft^3 sealed or 2.2@32 hz (small) or 4.0@22hz(large) each recommended box size.
SPY
SPY
NY
SPY
