TC Sounds 15" TC1000/EPIC/RL-i/TC2+
ciaonzo
TheContinental
11,703
76
WI
Old school US built 15" TC1000/EPIC/RL-i/TC2+, all the same. D4 coils.
A true unicorn among TC products, ultra rare and ultra SQ. Very highly sought after driver. Dead silent suspension and awesome output capability. Thrives on very little power and easily absorbs more serious power. Check out the specs below. I regret that it has some dings on the cone from loose items during shipment to me. I never let it bother me because I was so tickled to have even found one of these. I tried to capture them in the photos. Still presents very well and operates flawlessly. Moving soon and cutting down a little bit, get it while I'm weak in the brain.
Specs:
Fs - 15.6hz
Qts - .346
Qes - .381
Qms - 3.82
Sd - 320mm dia.
Vas - 393l
Bl - 15.01Tm
Mms - 283g
Cms - 433um/N
SPL - 87.8dB
The TC-1000 is the ideal driver for anyone looking for powerful clean bass with superb quality for either the home or mobile environment. With a standard 135 ounce magnet structure, 2" wide all aluminum 4 layer voice coil, and over 2" of highly linear excursion, this driver simply obliterates the competition. Its innate low distortion quality makes it seemly intended for high fidelity applications, but because of its high efficiency, impressive power handling and class leading displacement, the TC-1000 simply embarrasses retail SPL drivers with motors half its size! It can handle 400 watts of continuous power, but don’t be afraid to feed it 1000 clean watts as the voice coil will harness that power and deliver surprising sound pressure levels.
Advanced FEA Motor System
Double stacked 1" tall ferrite magnets and bored T-yoke for long throw
135oz top grade magnet structure
Anti-flux modulation copper shorting ring to lower distortion
Low carbon steel used for the gap plate and t-yoke
Pole vent for lower distortion and cooling capabilities.
Advanced high excursion soft part system
High excursion 8.0" linear roll poly-cotton spider
Intergraded woven leads to prevent lead-slap
2" diameter, 4-layer aluminum wire voice coil with an anodized aluminum former
Single or dual 3.7Ω (4 ohm nominal) voice coil configuration
Lightweight brushed and powder coated aluminum cone
1" wide long throw, highly durable NBR surround
High quality thermal flexible epoxies to ensure longevity
Performance
Effective motor force of 60 Newtons2 per watt (BL2/Re)
400 watts continuous power (1200 watts peak)
24mm BL XMax (voice coil, one-way)
37mm XMech (mechanically limited, one-way)
$300 shipped, CONUS.
CONUS only, please.
//content.invisioncic.com/y282845/emoticons/awesome.gif.4430a219d9aaaa6cadc75e9290979dfb.gif
please stop this XD, this would go quite well in my HT. decisions decisions...
Matt
Matt
You're all over the place, bro. lol
lol, i kno. i wont clutter your thread tho. but this is one sick sub. i have a Tapped Horn in my shed that this thing would destroy in. :-(
Matt
you should give it to me so I can dispose of it
ZOMG, is such creamy smooth bass, though. Loud with low distortions, from low power.
Made my bad day better with that one, lol. Thanks, man.
holy Fs of 15.. wow:emb:
Just keeps diggin', lol.
Looking for any trades my friend?
Would love to but I'm preparing for a move and positioning for other purchases, so cash only for now. Really sorry bro, you got some nice shiz.
Making a big UPS run tomorrow, would love to send this out to someone! Who wants it?
I was able to log in fine, using Chrome if that helps. I don't know anything about the product at all, just found the info and shared the love. :)
567
Brother in law has some of their 8’s and they are little beasts. Typical cookie cutter product that performs as it should.
Off the shelf design, nothing special and will sound like a bull horn. The best pro audio drivers I’ve heard are the crossfire XTpro6’s. The best...
The formula is Square Root of your target Wattage Multiplied by Ohms. 50Wx4Ohms=200. Square root of 200 is 14.14. So 15v AC is your target.
ciaonzo
TheContinental
ciaonzo
WI
ciaonzo
GoldCountryCA
    May 5, 2024
GoldCountryCA
    May 5, 2024
