Tang Band Group Buy
Come on guys...please buy some. These are some good quality midbass woofers, im getting some //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
to answer the last three questions, i've updated the thread to included power plate amps. Also due to the lack of high end extension the TBs would be best suited for a 3way setup or a HT 2way setup with a tweet that has a good low end crossover point.As for the last question, are you going to use it along with the kit and turn it into a 3way setup or use it as subwoofers. The 8s would be a better replacement to a subwoofer or enough 6.5s.
here's the specs for the 6.5,
Specifications: Power Handling: 50 watts RMS/100 watts max *VCdia: 1-1/2" *Impedance: 4 ohms *Re: 3.6 ohms *Frequency range: 35-800 Hz *Fs: 35 Hz *SPL: 85 dB 1W/1m *Vas: .51 cu.ft. *Qms: 2.81 *Qes: .32 *Qts: .29 *Xmax 11.5 mm *Dimensions: A: 7", B: 5-1/2", C: 3-5/8"
And the 8
Specifications: Power Handling: 150 watts RMS/300 watts max *VCdia: 2" *Impedance: 4 ohms *Re: 3.2 ohms *Frequency range: 28-1,000 Hz *Fs: 28 Hz *SPL: 84 dB 2.83V/1m *Vas: .81 cu. ft. *Qms: 10.53 *Qes: .30 *Qts: .30 *Xmax: 12mm *Dimensions: A: 8-1/4", B: 7-1/4", C: 4-3/4"
If people are interested in the 8in Neo magnet version i can get those too.
alteraudiousa
alteraudiousa
Concord, NC
JimJ
