Sold Take this amp off my hands...please
FineLinePimpin
Stuck in WV
For sale 1 used MTX RT2200... heres the specs...
RMS Power measured at 12.5 Volts DC:
50 Watts x 2 into a 4 Ohm load with less than .5% THD
100 Watts x 2 into a 2 Ohm load with less than 1% THD
200 Watts bridged into a 4 Ohm load with less than 1% THD
Dynamic Power (IHF-202 Standard) measured at 14.4 Volts DC:
85 Watts x 2 into a 4 Ohm load
140 Watts x 2 into a 2 Ohm load
280 Watts bridged into a 4 Ohm load
Signal to Noise Ratio:
100dB A-Weighted (Referenced to Rated PWR at 1VRMS Input Sensitivity)
Damping Factor: >200
Frequency Response: 20-20,000 Hz ±.25dB
Bass Boost: Variable Boost centered at 40Hz (0 to 18dB)
Defeatable 18 dB/octave crossover at 85 Hz, selectable for high pass, low pass, or full range.
Dimensions:
7" x 9" x 2" (17.8cm x 22.8cm x 5cm) (not including mounting feet)
8-1/4" x 9" x 2" (20.9cm x 22.8cm x 5cm) (including mounting feet)
Its a couple years old i would say....it came in my Tbird when i got it...and i have no use for it. I will post pics later tonight when i get home. Im asking 45 bucks Shipped ANYWHERE in the lower 48 states...You can check my references at ebay with the buyer name FineLineMtrSprts. I have also done some buying and selling on here. So 45 bucks it is shipped....get at me folks //content.invisioncic.com/y282845/emoticons/fro.gif.c695f1f814b01c4ad99fe7f8cccadd29.gif
Vince
FineLinePimpin
Stuck in WV
FineLinePimpin
Bunker Hill, WV
FineLinePimpin
