t20001 question
Does anyone know if the fosgate t2000 will go down to .75ohms. I know theyre rated at 1 ohm. I have a 9512G dual 1.5. 3 ohms wont get enough power so im wondering if i can use this amp at .75 without problems
Depends on what the box impedance rise is.
so basically im pretty much already seeing more than 1ohm load to the amp after box rise? will it be better to have it recone to a dual 1 to see a normal load of 1 ohm. After rise then the amp is gonna see more than 1 ohm and give out less power
Try it out and if the amp doesn't like the load then have the sub reconed to a dual 1.
X2 on try it first, but my experience has beent that RF amps do not like lower than rated loads. I have not run a larger T series amp though, perhaps they are more resiliant?
Redgp
Redgp
Tucson, AZ
Slammer
